1 - 6 of 6 Posts
I want to add a sink/toilet/shower at this location in the basement... there is a main coming from upstairs and directly under the toilet was this cap so I pulled it off and it was a drain pipe under it. can I add a toilet there? how could I instal a shower and where could I drain a sink? I can get water from the sink upstairs... Looking for some advice-be nice I'm a beginner! thanks!!
Photos
1. main drain line 2. hole that was capped off (you can see it at the bottom of the ladder leg in photo 1. ) 3. utility sink (just showing the layout) incase you have a better idea 4. above toilet drain,sink drain
· Plumb or Die!
The hole in the floor is a cleanout. You can't add any plumbing (around here) till you're 1.5 meters from the base of the stack. That means jackhammering and/or building a subfloor to accomodate your horizontal drainage pipes for a bathroom or whatever. You will also have to find a way to vent your new stuff. But I find, anything is do-able!
at the black cast iron pipe coming from the ground in the 1st photo on the opposite side of the photo there is a cleanout about 1' off the floor with the square looking bolt...why would I have 2 cleanouts so close to one another?
· Retired Moderator
so if its an abandoned stack can I stick a toilet on it? or is that the worst thing you've ever heard?
You are hoping to avoid jack hammering the floor?:whistling2:
Sorry---the only way to get the toilet plumbing to function properly will require opening the floor and adding a vent and the proper opening for the toilet---sink and shower/tub----
Mike
1 - 6 of 6 Posts
