Hello, I joined the DIY chatroom as I found someone had a similar problem to me but I wasn't able to get an answer. I currently am looking at adding stairs from my main floor to the unfinished basement. There is currently no hole for the stairs to go and so I would need to be cutting a for the new stairs. Upon looking into where I would put the stairs I found something odd with the joists in the basement. I found that there is a section of joists in an area where I would like to put the stairs going the opposite way of the rest of the room. Now I thought that it is possible a cantilever as there is a bay window but it just seemed a bit odd for that. I'm in Utah and the Utah code for width of stairs is 36". I measured the area and if you take a look at the images I have attached, the area from yellow highlight to yellow highlight is exactly 36". So I'm wondering, were these joists put in as an afterthought and as a designated spot for the stairs? As you can see these joists are connected to a triple joist and an exterior wall. i have attached an image as well as to what is above these odd joists. I'm not sure if it matters, but the home when the neighborhood was originally built was the model home.
Let me know what you think. Also if I decide to take these joists out and make it the spot for my stairs what things should I look out for? I've done a lot of deck stairs and decks but I've never cut into the floor, though I will have help from my FIL, he tends to make things seem easier than they actually are. Thanks in advance!
