I am an advid DIYer, but unfortunately there are only two outlets in my entire garage! For now, I am stuck with running extention cords as my tools fight for outlet space, but no more.
I did some research and found an idea where you can tap into the garage door outlet on the ceiling, run Romex in conduit across the ceiling, and about 3/4 of the way down the wall. Then at that junction, the conduit splits left and right, with a few outlets spanning across the wall in either direction.
While I do understand how to wire outlets, I am hung up at the junction. The feed comes down the wall from the ceiling into a box, and then from that same box, splits left and right. So essentially, I would have 3 Romex wires converging in that box, where I also have an outlet. My question is, how do I wire that outlet? I have a feeling I am overthinking this. I am making this project to code, so my solution does need to be to code.
Thanks in advance for any tips and suggestions!
