21 - 24 of 24 Posts
Remodel and New Build GC
Yes HK^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
There is something we don't know here... and likely something incorrect.
(OP.... not to alarm you, but many incorrect electrical sytems can function fine... untill they happen upon a certain condition, and then they don't... and that can present a danger... not saying that is your case, just there is something different here that we don't know/understand and can assess.)
MTN Remodel - the OP never mentioned a red wire, which is what I have seen in my houses. Essentially it is a MWBS using 14/2 rather than 14/3, and stealing a neutral from a different circuit. If he turned off the breaker for the first circuit, and there is a load on that 2nd circuit, power running thru the 2nd circuit is trying to return on the "stolen" neutral. That explains the spark when disconnecting the neutrals. I believe that what I am trying to describe is what used to be legal (back in the 60's) and was referred to as a "California 3 way". Google that, but you might bring up some unexpected videos. LOL!
JEFF...... Wow, I wonder.......maybe that's what's involved.
I just got up and have not looked that up recently, but I know what you are talking about... just can't remember the details any more.
Years years ago, fixing electrical in my daughters 1950 build in Marin, I ran into a three way I could not get working or figure what was occuring.... and it was a california 3-way..... can't even remember how I got tipped off or even discovered the concept/system.....
Basically, I don't remember it in terms of a screwed up mwbc.... more like a shared/crossed neutral or something....
Have to look it up again...
Best
Peter
Mike5163......Just out of curiosity..... (and maybe your safety,)
can you test the two breakers at issue/concern with a voltage (MM) tester to see if you have 240 across them or they are both the same leg at 120 (reading 0)
What year was your home built..?
21 - 24 of 24 Posts
