1 - 11 of 11 Posts
I want to add an additional electrical outlet to a circuit. Existing Romex on the circuit runs in the attic down the wall.
There are 2 options as I see it, since there is no slack in the existing Romex. Use 2 junction boxes in the attic to splice in to the existing outlet's romex or pigtail off the new outlet and use one junction box.
Thoughts and suggestions?
Retired Moderator
Either one will work just fine----I like #2 better ,but the cable might be stapled and impossible to remove.
Your call---both are safe.
Yeah, option 2 is doable, just harder.
Thanks for the verification.
I just wanted to make sure there wasn't some other way that was slipping past me.
I might get lucky with some slack on the line, who knows.
Super Moderator
Are you installing a receptacle above the exsisting receptacle?
Just cut a hole for the new receptacle, drop a new romex to the exsisting box and make connections there.
Discussion Starter · #6 ·
Actually this may work if I decide to stay in the same wall studs. I may move over wall studs though. Thanks for the suggestion!
A "Handy Husband"
Just thought about something.
How can I feed the new wire into the old receptacle's box? Won't that be difficult to feed the new wire into a tab on the old receptacle box?
Whats the technique?
I usually knock out the old box, fish in the new wire and install a replacement old work box.
Super Moderator
Drop a piece of string into the hole above the box. Use a piece of wire with a small hook on it thru the knockout to catch the string.
Discussion Starter · #11 ·
I had to rip out the old box to be able to fish the wire down to it. Tore a little bit of drywall, but nothing some spackle can't fix.
Had to twist 3 romex runs together + pigtail for the outlet. Tight fit in that old work box, but it made it.
Thanks for the tips.
1 - 11 of 11 Posts
