1 - 11 of 11 Posts
I am installing a new water softener, originally planning to drain it into a nearby floor drain, which feeds into an ejector pit, which contains a sump pump feeding into a horizontal sewer drain. I have read recently, however, the salt water is not good for the pump. Instead, could I add a new drain onto this horizontal sewer line at the same point the sump pump joins it?
I expect it would look like this? Replace the elbow with a T (or sanitary T? or wye?) to connect the sump pump and also connect a standpipe with trap and airgap device.
Is this a good approach? Is there a better approach?
Thanks!
Discussion Starter · #10 ·
What would be the normal way to do this?
I cannot just cut out a segment of the sewer line and add the Y fitting in. It is constrained on both ends, so I cannot move either end to get into the fitting. Would I cut out a larger section and add the Y with unions on either side?
1 - 11 of 11 Posts
