I'm a Real Estate Broker, who also enjoys doing a good bit of DIY work on my own house. Yesterday, a home inspection on one of my listings came back stating that the electrical panel had grounds and neutrals under the same screws. It occurred to me that my panel is wired the same way. From my research this was never technically correct, but there was confusion on the practice based on the manufacturer instructions. Something about the word "Grounding" vs. the word "Grounded"
Anyway, here are a couple of pictures of the neutral bars on my panel.
Right Side
Left Side
So on the right side there are two neutral bars. The one in the back is unused. It seems like it would be easy to fix this side by moving all of the grounds to the back bar.
On the left side, I suppose I could buy a ground bar and add it to the back of the panel, but I would have to extend all of my grounds to reach it. It looks like the panel was set up to have another bar installed to the left of the bus that's already there. Note the slot in the plastic, plastic nub sticking out, and screw hole in the ear right above the nub. Could I just buy a QO ground bar and install it there, to recreate the same situation as I have on the other side?
Thanks!
Right Side
Left Side
Thanks!
