I want to add more under eave ventilar ot reduce the tmeperature in the attic of my house. The temperatures reach close to 125 deg of on a hot summer day. The extreme elevated heat in the attic only became apparent after I recently had several trees removed (lost a lot of shade) . To complicate vinyl "hidden vent" soffit material was install several years ago. I remember the contractor removing the metal vents and clearing the openings prior to installing the vinyl material (he showed me). Anyway, I now have the heat problem. I have run the numbers and found that there was never enough intake vent area to begin. I am looking for advice on the most efficient and least expensive way to increase the intake area. Removing and re-installing the vinyl soffit material is complicated and expensive. I was thinking of cutting holes though the existing vinyl soffit and plywood underneath in new evenly spaced locations and covering the hole with white alumininum soffit vents. The holes would mainly be in the upper story (2 story houses), This seems like that it would wore but would it be noticeable ?. Any other options short of pulling off the vinyl and not those littile 4 in round vents ?It would take way too them .-Thanks
http://i33.photobucket.com/albums/d70/rkpatt/270housepics/IMG_20160616_200650333_zpsb5umepat.jpg
http://i33.photobucket.com/albums/d70/rkpatt/270housepics/IMG_20160616_200623064_zpststucw4i.jpg
http://i33.photobucket.com/albums/d70/rkpatt/270housepics/soffit vent 715751005180_zpsmwe2mbsr.jpg
