Hello there,
I just joined this forum today to ask a question that I can't figure out.
I enjoy fixing things and figuring them out on my own, but I am a super noob when it comes to electrical work. Be aware, there are likely some stupid questions ahead
I am adding recessed lighting to my basement.
There was already a ceiling light fixture that was controlled off of a switch. As I wanted the recessed lights to go off the same switch, I was planning on cannibalizing that ceiling light (no longer needed) and using its wires for my potlights.
However, my problems grew when I removed the ceiling light to discover the octogonal box behind it had 4 wires coming into it. 3 coming from the direction of the switch, with the 4th going off in the other direction.
Here is a picture:
Of the 4 wires, one of them is always hot (the one with the green tape) and is on its own breaker. But none of them turn off and on with the switch (other 3 are always cold).
This leads me to believe that the wires need to be connected together somehow to allow the switch to function.
Also, yes I am an idiot for not noting the connections to the ceiling light before undoing them. Lesson learned!
When I looked at the switch, I noticed something else weird (at least to me). I am accustomed to seeing the switch being used as the break for the black wire, with the white wire directly connected from the supply to the fixture. However, for the switch in question, the white and black wires are connected to the switch. Why would the previous owner have done it this way???
Here is a picture:
I am hoping some of you will be able to shed some light on this issue. I have the wire run for my recessed lighting already, I have been held up by this issue for several days now.
Thanks in advance,
Canehdianman
Here is a picture:
Here is a picture:
Thanks in advance,
Canehdianman
