1 - 12 of 12 Posts
Good afternoon new some input. I have multiple recepticals that are always live. There is one pretty much in the middle of all the wiring that I would like to add switch to just that one. It’s up high and only use it for a workbench light. I don’t need it on all the time so would like to possibly add a switch to it. Is it possible and if so what do I need to do. Thanks
I will prob look into that caseta switch. I also want to point out and I should have mentioned this in the opening post. All the wires are accessible still. The outlet I would like controlled by the switch is in the barn but I I’ve built a man cave lol in a section Of the barn and still wiring in there. I have not insulated it yet so I couls get to the wires still very easily. Do you think it’s still doable to add a wall switch or still look into the canseta switch.
· A "Handy Husband"
Run a 2 wire cable from the receptacle to the new switch location.
Sent from my Moto E (4) Plus using Tapatalk
· A "Handy Husband"
You should probably run a three wire cable (for Line, Switched Line and Neutral), since it is now a requirement that a Neutral be available at a "Switch" box - even if you do not think that you will ever use it.
Not required for a switched receptacle.
Discussion Starter · #10 ·
Just want to see if I can get a answer from here instead of starting a whole bunch Of threads. I have one last leg to wire in the man cave and it’s kind of getting me. I have power coming into a outlet Receptacle then going to a switch box. From there it is going up to the can lights. Now if that was all it was I wouldn’t be asking this. Now I need to get power to a outlet down on the bar counter. Could I run another power source from the switch to the receptacle? Would that be to many wires inside the switch box? There would be 3 wires going into the switch box, ( the power source, then one coming out for the can lights then another going out to the receptacle) thanks
1 - 12 of 12 Posts
