I know what I want to do, and it makes sense to me, but I thought I should check and make sure I'm not asking for trouble.
I have a bedroom wall with two existing outlets. They are combo receptacles where one receptacle of each outlet is always live and the other is powered by a wall swich - like for lamps.
I want to add two reading lights in the ceiling instead of using bedside lamps. My thought is to connect wires to the lamp/switched receptacle of each outlet on either side of the bed, run a wire partway up the wall to a new switch on each side of the bed, and then on up to the ceiling to power the lights.
So basically, I'm tapping into the existing circuit and adding two new switches and lights instead of lamps. Does that make sense?
