The doorway space I am looking to add would be approximately 32" x 8' 1st photo below shows the area in question from the living room, the other side of the wall is the hallway- the second photo being from the west end of the hallway (wall is to the right), the 3rd photo from the eastern end (wall in question is to the left).
It is an interior wall.
House was built in 1987- slab foundation, single story with tall ceilings and a rather tall attic. The portion where the insulation has been removed is about where the opening would be- I would like to remove the two studs closer to the left of the opening, and place one new stud right next to the lower middle electrical box- the box seen above this one is for the doorbell, this I will move.
The box to the right is for a phone jack and I will get rid of that. I would place another stud to the right of the existing right hand stud and attach it to the stud in the corner. I would then proceed to remove the other studs.
My question is about the diagonal 2x4 - I assume it is shear support, though I'm not sure why the lateral bracing is needed here, or if necessary. It does not go all the wall to the corner of this wall but ends in the corner of the vertical stud that is second most to the left (the next stud over from the one seen in the corner).
I am located in Northern California, a few hours south of Oregon border. Thoughts would be appreciated.
