Here's the situation that I have:
My house was built 5 years ago in New Jersey, everything was done by the book and fully scrutinized including the proper amount of fiberglass insulation being installed (as far as code requires, I am not sure exactly what R-value it is though).
Under the house is a large 4' high crawlspace. The floor is made up of TJI joists. The fiberglass insulation doesn't come to the bottom of the TJI, it's about 1-2" short.
I would like to add more insulation since the floor is always cold. I think we are having thermal bridging problems since the bottom of the TJIs are exposed.
It would be easy for us to just screw styrofoam insulation panels to the bottom of the TJI's across the entire crawlspace, but I have two concerns.
My first concern is that there will be a 1-2" gap between the styrofoam insulation board and the fiberglass, is that OK? Second, the styrofoam will be a second vapor barrier because I assume there is already craftpaper on the top of the fiberglass where it is touching the bottom of the floor. Will that cause issues?
