Hello,
I am looking at retrofitting my home by adding exterior insulation. I'm not sure on the best way to do this to avoid moisture issues. I live in North Western Ontario and our climate can get as cold as -40 degrees C and as warm as +35 degrees C and humid.
The house is of milled cedar log construction. The logs are roughly 4" x 7" and feature a double tongue and groove. The house was built in 1971 and insulated on the exterior not long after with 1" styrofoam and then cedar siding. I plan on removing the siding and the insulation and replacing with something better. The cross joints stick out 5" and "section" off the exterior of the house. I will add pictures shortly.
I'm thinking of a few different options:
- Framing a false wall with a space behind similar to an insulated basement wall to allow 1" spray foam behind. Then insulate the cavity with bat or cellulose insulation.
- Building a false frame wall (larsen truss possibly) and using a sealer paint on the logs as a vapour barrier and then blow in insulation in the cavity. Could also use a poly on the logs but it will be hard to seal.
I've been scratching my head on this for a while... any advice or opinions would be great help.
Thx
Thx
