Last fall I remodeled my detached garage. Insulated the heck out of it and I installed a new Goodman 45KBTU (maybe it was 48?? dont remember) for heat. It is a 95% efficient unit that was set up for NG when purchased, but I converted it to run on propane. Heat has worked flawless and I did not install AC at the time figuring I will add it after the cold weather...
Question is... is AC just as easy to install for a DIY'er like myself? I will be stopping by the supply house this week to pick up what I need, but wanted to ask on here for any tips/tricks I need to know. All I "believe" I will need is an a-coil and a condenser, along with power, which I have plenty.
Someone (just a home owner, no a pro) said to me after saying I was going to install AC to the system.. "you are going to have to sweat copper"... ok... if that is going to be the biggest hurdle, then I should be good to go, unless there is something more to sweating copper lines then there is with standard water plumbing... Again, just wanted to check.
I am sure I will have to call someone to charge the system, correct? or can this be done myself as well?
Thanks in advance for the help!
