My foundation is a little weird. It is a poured cement foundation c.a. 1960. But the footing hight is all over the place, some places it's way above the floor, some places it's way below. Where it was below, it created a bit of a cavity which I did fill in with some floor leveling cement. But theres still lots of spots where not only is it unappealing to look at, but there are several places where there are gaps at the floor line where water comes in when it rains heavy, critters can still creep in, and there are a few spots that always look moist.
I want to use a drylok wall paint product on my walls to seal them up, but I think I need to deal with the floor/wall seem first.
Over at my grandmother's house, her basement has this nice beveled edge all around the floor. I'm thinking something like that would be nice and helpful here to help seal the gap and fill any voids before painting on a sealer.
Is this the right approach for this sort of thing? If so, what is the right cement to use for the job? And do I need to do any prepwork? In some places, it would be a transition from the wall to the footing, which are pretty rough surfaces. But some places it would be the wall to the floor, and the floor is quite smooth. I wouldn't want this newly added cement to not "stick" to the surface. Maybe the solution to that is roughing up the surface? If so, what's the best way to do that? Sounds like labor intensive job.
If it's not clear what I'm talking about doing, here is a diagram. Just a simple little angled bit of cement, ultimately going all the way around the basement. Probably no more than 4 or 5 inches in size:
