1 - 8 of 8 Posts
I am wanting to add an outdoor outlet for my chicken coop. It is located right by our wellhead ( we are on well water). Would it be totally ghetto to branch off of the well power supply to add an outlet or is this ok? I think the most it would be powering would be a heat lamp. Thanks in advance?
Probably not as the controller for the pump is likely inside near the pressure tank and you will likely have power only when the system turns the pump on. In any event it's probably 240 volts with two hots and a ground.
1 - 8 of 8 Posts
