My house is heated by an oil fired boiler feeding 4 zones of baseboard: 1st and 2nd floors, basement, and a room above the garage. The 1st floor loop includes about 20 feet of baseboard in a sunroom that we don't use in the winter. We keep the room closed off from the rest of the house when not in use.
I recently did a Manual J calc on the house, and found that this sunroom is about 20% of the heat load of the entire home and contains about 10% of the baseboard. I'm looking to save some $$$ by not heating this room at all in the winter, but would still like the option of heating it in the fall / spring. Would the following solution work ok?
1) Put a ball valve on both the supply and return pipe where it branches off for the sunroom in order to isolate it from the rest of the loop. These are only separated by a few feet in the basement.
2) Within this now isolated loop, add a valve with hose connection in order to drain / fill the loop as needed.
3) Add a connecting piece of pipe to complete the loop, also with a ball valve.
Best attempt at a before / after diagram:
Before:
.......________
After:
.......________
.......h......... h
I know the best solution would probably be to remove this room from the 1st floor loop, and put it on its own zone. But I don't want to go through the added expense.
Before:
.......________
After:
.......________
.......h......... h
