Hello,
I have seven lights on the same circuit and am trying to add a switch to one group. I added a switch loop to the group I wanted however it is controlling everything to the end of the run. See below for how I am setup.
I have this with all wire being 14/2 and all but the last light on pull strings...
Power - L1 - L2 - L3 - L4 - L5 - L6 - Switch - L7 - Outlet (constant power)
I'm trying to do this...
Power - L1 - L2 - Switch - L3 - L4 - L5 - L6 - Switch - L7 - Outlet (constant power)
When I wired a switch loop at L3, it controlled everything including the existing switch at L7 and the outlet. It doesn't pass power beyond L6 when the switch at L3 is off. I want L7 and the outlet to continue having power whether the switch at L3 is on or off. Given my current setup, it should be possible because the outlet after L7 has power whether the existing switch is on or off. I think I'm missing something simple but can't figure out what it is.
Any help is appreciated. Thanks!
