I am installing a standby generator for my home.
I am adding a 100amp sub panel adjacent to my 200amp main in my garage. I will move 22 essential circuits from the main panel to the 100amp sub panel. The sub panel will be controlled by a 100amp automatic transfer switch with a 20kw standby generator or a 100amp breaker from the main panel.
To move the circuits to the sub I must splice the circuits with wire nuts in the main panel. Wires are not long enough or accessible to reroute them to the sub
My question is: Is it OK to just move the HOTs for each branch circuit to the sub panel and leave the neutrals in the main. There is a #2 neutral from the TS to the main neutral bar and to the sub panel neutral bar (not switched)
I am trying to minimize the splices (wire nuts) required in the main panel (24 versus 45 if I move the neutrals). I am using a 2-1/2 “conduit from the main to the sub. If I move the neutrals I would have 3-#2, 1-#6(g), 5-#8, and 40-#12.
I think I know what the answer is (move the neutrals) but I just want verification and a reason.
Thanks in advance
Thanks in advance
