Forum newbie here. I ran a search but didn't see a thread that quite matched what I was looking for.
I'm planning on adding an electrical sub panel to a garage approximately 250 feet away from the main panel. I already have 2 inch conduit with 2 ft sweeps running underground from the main to the garage. The main panel is a 200 amp breaker box with 4 empty spaces. My plan was to add a 100 amp breaker into the main box, use 2/0 triplex wire with two hot wires and one neutral and ground the sub panel at its location. There aren't any other services connecting the house to the garage. Inside the new shop I'd like to have the ability to run a 230 volt air compressor along with a dozen fluorescent lights and have a couple of breakers worth of 120 outlets. Should I proceed as planned?
thanks for your help...
