I currently have a single porch light on the left side of my front door. The switch controlling the light is on the same side of the door. I’m looking to add a second light to the right side of the front door, controlled by the same switch. The actual wiring part should be a breeze as I’m comfortable with basic electric work.
I’m looking for tips/tricks to run a cable from the existing light fixture to the new one. I have a two story house, so the path will be through the basement.
Thinking I need to get a right angle drill attachment to make a hole through the bottom plate, going up from the basement? Hope there’s no blocking in that wall. I have fish tape, any tips for doing this on an exterior wall dealing with insulation and getting it to the new hole on the bottom plate?
The current fixture doesn’t have a box. Just a small hole was drilled in the wall to fit the cable through, and a bracket screwing into the vinyl siding. Wondering if it would be best to make a bigger hole there and add an old work box?
Thank you for any insights you can offer.
