Adding a new switch for recessed lights to existing 2 gang box
405 Views 3 Replies 2 Participants Last post by  jfguerrero1
Hello Everyone. I am doing some remodeling and I am adding recessed lights to the living room where there is currently only one light source - from a ceiling fan - in the middle of the room. It has always been quite dark in the room so adding lights will greatly improve the lighting, (and my mood :vs_laugh: ). I am adding multiple LED recessed lights, strung together around the perimeter of the room. The current electrical source is a 2 gang box that has 4 cables coming into it. Two cables are 12/3 and 2 cables are 12/2.
The 12/3 cables run the ceiling fan motor and lights from 2 different switches and 2 different locations: two switches from one entry/exit point into the living room, and the second 2 switch set from another entry/exit point in the living room.
The 12/2 cables: one comes from the breaker box, the second goes to an outlet close to the switch box.
I have already replaced the 2 gang box with a 3 gang box and I have added the new (12/2) wire from the living room ceiling (recessed lights) to the switch box.
I need to know how to connect the wires to provide power to the new recessed lights.
I am adding a diagram of what the wiring looks like, as they are connected in the existing configuration.
Thank you in advance for your knowledge and help in making these connections.
Adding picture of 3 gang box and wiring.
Not sure why you have three screws on the switch but this should do it.
Text Diagram Organ Joint Human body
Awesome! Thank you joed!!!
