Did the inspector not suggest a lentil plate across the top of the block? Seems to be a lot easier to do. Pictures always help us see what you see.
Move what? The window?Do you have 4" below the window to move it down.
Well he did say proper joists hangers need to be used.And he had no issues with the metal corner bead being used on the joists?
Yes can you move the window down 4"Well he did say proper joists hangers need to be used.
There would be here.I would ask to see code rule on that. With I joist hangers there should not be a need for a header there.
Sorry I don’t understand could you explain further please.If the header is holding up the joists using joist hangers then the header is positioned like a rim joist.
The header, to still be called a header, needs to sit on top of jack studs..
Doing it this way you don't have to move the window down to make space under the joists for the header, and the window offers more headroom (no pun intended).
You would go in the outside above the window and remove the rim joist 3" wider than the window on each side.Sorry I don’t understand could you explain further please.
Yes the duct will be movedOops, I missed the heating duct in the joist bay directly above the window. Can you or did you relocate that duct to obtain the picture just below the picture with the heating duct?
If you have to keep the heating duct there then the header has to go below that. Now you are back to a traditional header (below the joists). and you have to work around the limited headroom.
After a good night's sleep I got the words I wanted, sister the rim joist with the header, which idea you/I have to abandon because of the heating duct.
A double rim is always called for when it is used as a header. Where I live anyway.I would ask to see code rule on that. With I joist hangers there should not be a need for a header there.
Eh?
That sound like the answer here.Did the inspector not suggest a lentil plate across the top of the block? Seems to be a lot easier to do. Pictures always help us see what you see.
