I have a large play room. It's about 10x30' and we want to add a closet. Do I need a permit? I think we will need to add electric for lights. Will that need to be inspected?
Normally you need permits, and yes get your electrical inspected, and if you don't know how, get a professional electrician to add the circuit to the breaker panel.
I doubt you need a permit. Even with my bath remodel where a new electrical line was installed to provide the code required dedicated 20 amp line there was not a permit required and I used a licensed electrician.
The carpenter who builds out the cabinet is not the same person who should be running the lights for the closet. For a walk-in closet I would want lights but for a regular depth wall closet a light is not essential.
The closet lights can use the same leg that is supplying the ceiling lights in the room now and add a switch or switches for the closet. If there is access from above in the attic then this is a trivial job as the electrician can run Romex from the ceiling light box to the new boxes for the closet ceiling lights.
For any work a contractor will ask whether you plan to pull permits. When I have said I was not going to get permits I have never had a contractor turn down the job regardless of the scope with the exception of roofing and solar installations. I added a natural gas feed standby generator and it was put in without permits but I did use a licensed electrician and a licensed and certified plumber.
Good idea to go to the website for the local building and permit department as it will specify what work does and does not require a permit.
