Added new popup sprinklers and pressure is horrible... Advice please!
Hi Everyone,
I attached a rough layout of my predicament. I decided to finally take the plunge and add some sprinklers by the road so we can finally start growing grass on the other side of the sidewalk. I managed to tunnel under the sidewalk and hook up 4 new sprinkler heads (purple) with no problem. However, now my pop ups do not have enough pressure and the new ones do just about nothing...
Doing some research, I decided to drop down to 1/2" PVC (from 3/4" on my existing system) on the other side of the sidewalk to help with pressure. The red dots were my existing 4" popups (all on a single zone). I decided to remove the one by the sidewalk and turn it into a flowerbed. In turn, I teed off the connection and went under the sidewalk. The pressure was lousy so I also capped off (at the riser temporarily to see if it helped) the two heads by the fence/house. They were still leaking a bit but still not enough pressure...
What do I do now? Would permanently capping those two heads help? Do I need to separate these into separate zones? I was hoping to avoid digging up my lawn so that's why I removed a few heads and hoped it would just even out... Any advice from the experts?
Thanks in advance!
Hi Everyone,
Thanks in advance!
