1 - 8 of 8 Posts
Hi,
I have a space in basement which is going to finish soon. I don't have space to run a separate Flexible Duct between joists to this place.
So I am planning to reuse the existing Flexible Duct and create a tee and then attach boot
But what register vent boot, do I have to use which is compatible with duct tee?
Any help will be highly appreciated.
Thanks
Administrator
Does the existing duct supply a room on the upper level, or the basement.
Administrator
Then you'll be taking heat a way from that room, and it will now be a cold room, and the basement area won't warm up either.
I think its same thing. isn't ?. Even though if you add new one. Ultimately you are basically splitting the air flow from main stem into one more. Both/All the spaces will take little more time to heat the their own space. Right now I don't have space for new one. so now I am in situation of "Something better than nothing". Please correct me if I am wrong here. I'll be adding for return air in the floor.
Thanks!
Administrator
If you take from the main truck, as you said. All supply lines loose just a little, and the system runs longer.
But if you take from a supply branch, then you only reduce air flow to that one room, and the system doesn't run longer. Making that room cooler.
Reactions: viky
What you have mentioned above I am agree with you.
But in my case, that supply branch going the upstairs main living area where thermostat located. If it was for a room yes it would have definitely run for same amount of time ( as before) and would have make room cooler.
But here, I think it will run longer, because I am stealing heat from main living area.
Administrator
Maybe it will work okay. Or maybe it will run longer like you said, and over heat the other rooms on the upper level.
1 - 8 of 8 Posts
