My pantry is behind a single door that opens and closes similar to a bathroom door. Inside the pantry are about 4 shelves. There are no power outlets inside the pantry and no light switch so the pantry is quite dark even during the day since it's not in direct line of sight to a kitchen window.
If I want to add some kind of LED strip lighting along the edges of the wall at about a 45 degree angle pointing towards the items in the pantry is there a product you would recommend? There is an outlet just outside the pantry on an adjacent wall so I can probably drill into the drywall and just run a power cord to that outlet. I would be looking to run strip lighting on both sides of the door so if there is a way the two strip lights can connect to each other so they can be powered off one connection that would be ideal.
What about any battery powered strip lights or some kind of battery powered automatic lights so as soon as the door is opened the lights illuminate? Anything you would recommend? Thank you in advance.
