OK, so here's my situation. In my garage I have a switch. When looking in the box, I see one cable coming in to power the switch. The wire has a white, black, and bare copper. The white wire has been marked red indicating it is "hot." The switch is single pole and has the marked white wire, black wire, and ground wire going into it. When this switch is "on" it fully powers two separate outside receptacles under the house eaves.
My proposal, I'd like to be able to run off this switch to power additional receptacles inside of my garage.
My plan: Remove mark on white wire and extend this existing cable into another junction box with two receptacles.
In existing switch box, add an additional outlet and the existing switch. I'd connect everything to the one existing wire and hope all the receptacles would then be powered by the switch. Is this possible?
I'm attaching pictures in the hopes this will make more sense and someone can give me feedback.
