The following post is opinion. Some people on this board hate all opinion. Your best way to resolve this is to not read this posting. Reading it anyway then being unhappy is not a good plan.
I am buying a table saw that will run best on a 220 outlet. I will eventually wire my shop with a 220 outlet, but that has to wait for now. In the meantime, I wanted to use the dryer's 220 receptacle which is conveniently right next to the garage.
The table saw has a 220 volt NEMA 6-15 plug, and the dryer receptacle is NEMA 10-30R.
*screech* whirr crunch. That ain't good!
FACT: The NEMA 10-30R is an obsolete type of receptacle that does not have a ground wire. It has a neutral wire instead.
FACT: Manufacturers got a special exception cut into NEC that allows NEMA 10-type receptacles to be used for decades after everything else required grounds. Further, they got an exception to allow "grounding" the appliance by attaching it to neutral. The problem is, if the neutral wire comes loose, the appliance chassis is then electrified, and can kill people.
(opinion) And has. This is a very bad way to hook up *even a dryer*, because this exception was ill-conceived. The logic of the appliance makers is "that's not likely to happen, because dryer receptacles are very rarely disturbed." Also, NEMA 6/10/14-30 are not made for frequent interchange (L6/L14 are). Now, what are you about to start doing?
Your best play is to change that receptacle out to a NEMA 14-30 after either
a) discovering there actually is a ground wire or grounded metal conduit there after all,
b) retrofitting a ground wire, or
c) skipping the ground and going with a GFCI breaker. This requires labeling the 14-30 "GFCI Protected/No Equipment Ground".
This is something you should do regardless, for your family's safety. As part of this you would remove the neutral-ground jumper from the dryer, so ground goes to ground and not neutral. (most especially important with the GFCI option!)
I found an adapter at home depot
here that seems like it will work. I also read that "the cross-compatible NEMA 6-20R can accept a 6-15 or 6-20 plug".
Well, things which plug in are outside of NEC's jurisdiction, so it's not a Codevio.
Look for a "UL Listing" on the item. If you find a UL Listing, that means it has been built to UL's safety standards (White Book) and UL has independently confirmed that. Also acceptable is CSA, ETL or any of several other Nationally Recognized Testing Labs (NRTLs), you can google the list of current NRTLs.
CE, CCC, FCC and RoHS are not testing labs.
If UL or other NRTL endorses the adapter, then I cannot say a word to protest.
However here are my concerns:
- Connecting ground to the NEMA 10 neutral. This inherits all the problems that makes NEMA 10 so dangerous, but lacks the mitigating factors. You can cure this by changing to NEMA 14 as discussed above.
- Connecting a 15A load to a 30A breaker. The general problem here is that the 15A load could suffer a serious overload, and the breaker would never even know it, and would just let it burn. Now, UL accounts for that as part of their certification of appliances. Anything that plugs into a 15/20A circuit must be designed so if it has a problem, a 20A breaker will save it. A 30A breaker is not part of the spec and is not tested or certified for.
The reps at the company that sells the table saw say it's okay to use an adapter. I like to trust but verify, so thought it was worth a post to see if anyone has experience with this kind of thing and can confirm there is no potential to damage the saw or outlet.
Did they say "An adapter" or "ALL adapters"? Because SOME adapters would be OK, but not that one again, in my opinion.
If you already have a ground wire or metal conduit back to the panel, one option here is to fit a subpanel here. It can be a $20 cheapie, even. Into this subpanel you fit a 30A for the dryer, and a 15A for this saw.
Wow, that was easy.
I can't tell you to retrofit ground to that location
and then fit a subpanel, because I don't think you're allowed to do that in one step.
So, you can not plug a 2 amp lamp into a 20 amp circuit, or a 15 amp table saw into a 20 amp circuit? I call BS.
Call UL.
