I'm trying to configure my thermostat's system key to be "auto", but the instructions are not provided in the owner's manual. Basically, i have to manually change the thermostat to be in "cool" or "heat" mode. I want it to be set to "auto" so that it adjusts itself based on the temperature. My contractor who did my previous home said it was easy but would like someone's guidance on how it should be done.
thanks
Discussion Starter #3
thank you, but what I really needed was to add the "auto" option to the System setting since the default factory options are Heat, Cool, and Off. The tech support can only provide directions to the licensed A/C contractor. However, I was able to figure it out by really the installation manual. You actually have to configure the setting using the User codes.
