As you can see in the photo, the access panel to the evaporator has the the connections blocking easy access. It seems that I could get in there, but it looks like a pain. I can get to the top of the evaporator through the register just above it, but I suspect that the bottom is what will need the most cleaning. My thought is that I could cut an access opening in the rear, and not deal with the connections located in the front. Assuming that there is enough clearance at the rear to allow cutting into the cavity, is this a good idea? Any other thoughts or suggestions?
