I took down a knotty pine wall covering to add insulation to a room in my house and discovered significant old termite damage to the sill, studs, and a long header that is above two windows on that exterior wall. This is old damage and there are no active termites. The exterior wall is part of a 1 story ranch and that room is on a concrete slab. I have had a few contractors come in for quotes and essentially received 2 different approaches on how they have proposed to address it. The quotes received vary dramatically as the highest is almost triple the cost of the lowest quote - likely due to a big difference in approach. No approach is "cheap", but some are really expensive. I was hoping to get an opinion on the validity of the less expensive approach.
All agreed that at least several feet of the sill, a few wall studs, and at least several feet of the header needed to be replaced due to termite damage. The less expensive approach (#1) involves putting in a temporary 2x4 wall, cut out and replacing several feet of the sill that is on the exterior slab, replacing damaged wall studs and replacing a section of the damaged header. Then, the bottom section of plywood sheathing along the sill on the outside will be replaced (quote doesn't include house wrap and reshingling). Several feet of the termite damaged header (two 2x6s about 12 feet long) above the 2 windows will be cut out and replaced. This header was original to the house before that room/wall was later converted to finished living space from a breezeway.
Approach #2 involves demoing all of the studs, sill, header, sheathing, and reframing that wall. The 2 windows will be reinstalled, the entire exterior sheathing, house wrap, and cedar shingle siding will be replaced, even though only the sheathing closest to the damaged sill appears to be termite damaged. This additional scope of work is probably why the quote is more than double - almost triple the price of approach #1.
Approach #2 sounds fine, except for the quoted price I have received (note: I am still awaiting another quote on this scope of work). Approach #1 with the reduced scope of work is about 1/3 the price of the 1st quote from approach #2 (but still not cheap). Usually a 1/3 the price of another quote sounds too good to be true and may be a red flag, but the price on approach #1 was more in line with what I was expecting and the price on approach #2 was a shock... All contractors seem reputable based on preliminary research and no obvious red flags from in person meetings.
Is approach #1 a feasible and a structurally sound plan? Any concerns I should have with this approach? Based on price, I would obviously prefer the significantly less expensive option, but don't want to take on an approach that may be substandard, not pass inspection, and/or balloon in cost significantly after the initial quote and scope of work is agreed. Any advice is appreciated. Thanks.
