You are getting Phantom voltage because of your meter. To get rid of those, you have to use a load such as a light bulb on the line to with one end to the positive (red) meter lead, the other lead (black) to the line coming from the breaker. Should get zero volts from Black to Neutral, Black to Ground. Measuring White & Ground will always show Phantom on a cheap fluke.
