1 - 20 of 23 Posts
Last night my AC stopped working. The thermostat fan was set to auto and that continued to blow air no problem, but after awhile I noticed it was getting warmer and warmer. I checked the AC outside and it was not working. I tripped the breakers a couple of times, and nothing.
My wife tried turning it on this morning and said the AC unit clicked like it was trying to start up, but nothing happened.
I'm hoping this is an easy fix (fuse?) Any ideas where to start?
Thanks
Jeff
You need push ( close ) the contactor. If condenser start to work you have to check 24Vac at contactor. Use something that does not conduct electricity to close the contactor.
Sweet! Thanks!
So, cut the power, use something non-conductive (a stick, etc?) and just push that back in place?
Seems a fairly easy fix. I'll keep ya'll updated on how it goes when I get to it later tonite when I get off work.
Thanks again!
No fix yet. We're only troubleshooting. Let me know what happen.
Discussion Starter · #7 · (Edited)
Ok, I tried pushing in the contactor. Is it normally a bit springy? Turned the power back on and then thermostat over to auto. The inside fan starts up, but the AC unit isn't doing anything.
Edit: I pushed it again with the power on. Something started to make a noise for about 5 seconds, and then stopped. No movement.
Now what?
When you push ( close ) the contactor fan and compressor should start running. Do you have a multimeter and know how to use it?
Discussion Starter · #9 ·
To add to the last post. I left the Thermo on Auto for about 5 minutes. The AC unit sounded like it wanted to start, but didn't. Made a noise again like it was going to start up.
Reminds me a bit of when a battery in a car is about to die... just that whhhhrrrrr kinda noise... last about 5 seconds and then stops.
IN should be your line voltage
OUT - Should be the same as line voltage with contactor close and 0v with contactor open
you should have 24vac when the thermostat calls for cooling. If you have 24vac but the contactor don't close you have to check if the coil is open.
does your system have 1 or 2 capacitor?
Discussion Starter · #13 ·
I'm only seeing one capacitor in there. Here is a pic:
Replace your capacitor....It's BAD :thumbsup:
Discussion Starter · #17 ·
Sweet! Easy fix... and not too costly! :thumbsup:
You guys rule!
Thanks so much! I'll update you when I get a new one installed.
Anything I should know about installing a new capacitor? It looks like a fairly easy switch out.
Do not use your hand to disconnect the wires. Discharging a capacitor means taking safety precautions and dissipating the energy from a capacitor.
Discussion Starter · #19 ·
That's about what I figured... I'm a photographer, by trade, and work with big strobe packs with capacitors in them. I've seen a couple explode over the years, and even know a guy that lost a finger when he had 2000 watts arc out on him :)
Cool, I'm a photographer also. :thumbup:
1 - 20 of 23 Posts
