I have a Coleman 3 ton package unit w/ reciprocating compressor. Last night unit made load noise when coming on, when I turned it off, it made a load whistling noise, turned back on . Then it threw breaker.Blows warm air. There is clear oil coming from bottom of unit. Compressor bad???????
Hvac Pro
This could be a VERY DANGEROUS SITUATION. Oil leaking out means the compressor may have blown the fusite (fusible electrical plug) where the power goes into the compressor. You may have a dead short in the compressor and LIVE HIGH VOLTAGE to the shell of the compressor which can electrocute you or anybody who touches the outdoor unit if you reset the breaker. Call an experienced qualified tech to find out what happened and leave it OFF for now.
Administrator
If you have oil coming from the bottom of your condenser. It needs more repair work then you can do.
