Sorry, the compressor is NOT engaging.Still not sure if the compressor runs or not.
I saw the mistake but I could find an edit button if there is one.
:glasses: :glasses: :glasses:
Thanks.............I'll give that a try......the AC in this thing was like a freezer last year.Then as noted above: most likely low refrigerant. Could also be bad relay, bad compressor clutch, bad low and or high pressure switches, bad control switch on dashboard, bad wire... etc. But the $ is on low refrigerant. Put some gauges on it and see what you got.
