I am having to replace the condenser fan motor due to bad bearing/burn out. Here's where i am in the process:
Got the new motor. The old one had 3 wires, red, brown and black. The new one has brown, brown/white stripes, black, and white.
I also got a new run capacitor. This is NOT a dual cap. Some weeks ago, i had to replace the capacitor but somehow could not get the dual, so i have to separate one. Start and run.
OK, so, I got most of the wiring straight now. The brown and brown/white go to the run cap, while the black and the white will go the contactor. However, with the last 3 -wire set-up), there was a black wire that connected the run cap to the start cap.
So my question is: what do i do with this black wire now that i have the two brown wires connected to the run cap? Does it mean that one of the terminals on the Start capacitor will be useless and i should cap it off?
Second issue has to do with hooking up fan blade: new motor shaft is way to long and i need to cut it. HOwever, even when it will be cut, i wont be able to get blade all the way up against motor as blades would it sides of it as well as some bolts from motor casing. So question is: will the set screw stay in pace and be strong enough to hold blade in place even if located mid-shaft?
Thanks!
Thanks!
