Last night I was woke by our water alarm. Turned out the AC is continuously running for like hours (to drop temp from 26 C to 24 C), and the condensation water overflow to furnace and ground.
I vacuum out lots of water from the bottom of furnace.
It looks like there were water dripping from the joint of the condensation pipe
The drain pipe have a little but not much water flow. I used a shop vac tried to vacuum it, also tried an auger. The auger did get a little bit dirt and some water but not much.
Later with most water removed, I tested the AC again. With 20 mins running, the water is dripping again. There was some water flow from drain pipe when I moved around it (it was a little bit angled up), but the main dripped came from the pipe joint.
When I removed the red cap, water is flowing from here.
My question is:
1. With 20 mins AC running, the condensation water look to be around at least 200 ml. Is this normal? The humidity in house is around 72% according to thermostat. I read that with some problem in AC there could be extra condensation.
2. Now I think the drain pipe don't have serious clog, why is water came from that red cap? Should I seal it somehow, like apply some telfon tape around the cap thread, or this is caused some other problem inside? The putty like black stuff also have some gap below the joint.
Thanks!
My question is:
Thanks!
