1 - 6 of 6 Posts
Need some help. I'm trying to have the maximum torque on a shredding motor that can run off of a regular household plug (15amp). I've been buying all kinds of motors to no end. Any suggestions on what is possible? My goal is maximum torque (lb-in) with RPM's around 40 if possible, but can settle at 25 if need be. Need forward and reverse, etc. I'm connecting it to an industrial grade shredder and i just can't find out the limit.
A parallel shaft, single phase is what i've been using. If there is a simple formula, i'm all ears. I'm just terrible with electrical stuff. Your help is much appreciated!
You need a gearmotor, which is a motor with a gear reducer mounted on the end. Any gearmotor will have output RPM and torque stamped on the nameplate. I don't know how much torque you are looking for, but most common 115VAC motor speed is 1800 RPM, so gear reducer would have 45:1 ratio on it if has 40 RPM output speed. Parallel shaft gearmotors are common.
Disrespectful to dirt
That's going to limit you to 1/2 HP maximum.
You may derive the maximum torque available using the standard horsepower formula of:
HP = (Torque x RPM)/5252
Torque solves to:
Torque = (5252 x HP)/RPM
Using the .5 HP and the stated RPMs yields:
40 RPM - 65.65 lb-ft
25 RPM - 105.04 lb-ft
Actual shaft horsepower after the reduction gearing will be less so the torque will be lower as well, but this gives you an idea of what is possible.
if you dont want any gearbox than go into stepper motors they produce a lot of torque at low rpm but they need drivers, power supply,...
For this application a gear motor is the very best suggestion.
You get a base shaft output speed you can count on and a gear motor of this size would be very inexpensive.
Attach a cord and plug and connect the load and off you go.
https://electricmotorwarehouse.com/parallel-shaft-115v-208-230-460v-482-series/
This link is just an example. A Google search for AC gear motor will provide everything you need.
Make sure it is reversible and get the switch at the same time you buy the gear motor.
1 - 6 of 6 Posts
