my project started out as a simple lighting fixture change and now i'm in a real state of confusion. i'll try to explain as clearly as i can and hopefully someone will understand and help me finish this job...
1. i'm trying to swap an old lighting fixture for a newer one.
2. the fixture is controlled by a dimmer switch (the round kind).
3. i've removed the fixture as well as the switch (yes, i remember which wires went where).
4. the junction box in the ceiling has three wires. two white wires and a green wire. none of these wires are hot (i tested them several times).
5. the switch junction box has one black wire and one green wire (the black wire is hot)
6. there is a switch for another lighting fixture on the opposite wall, which is where i believe the black wire is getting it's power from.
7. when i removed the old fixture, all wires were connected. the two white wires in the box were connected to the two fixture wires with one large wire nut. the green wire from the box was connected to the green wire from the fixture.
8. when i removed the dimmer, the old dimmer had two black wires coming from the back. one was connected to the black wire in the switch box and one was connected to the green wire in the switch box.
9. i am terribly confused.
10. i've swapped many a fixtures, but i've never seen anything like this before!
i'm trying to remember if there is anything else, but i think that's all. please help. thanks.
