I have a wierd situation and could really use some advice
An addition was built on a house that already had a small concrete walled room in a basement, this added room surrounds the small room in the basement in an L shape. The only access to it is a 26" x 18" hole in the wall, it is a sand filled crawl space and the room above it is cold because there is only insulation stuffed between the joists. there are 2 holes in the exterior walls I assumme are for ventilation, Should I put a vapour barrier on the ceiling of this room and seal the holes leading outside?
I hope I have explained this well enough...
Thanks for listening
Artie
Artie
