Now I never called myself a real Jack of all trades but i've completed a lot of really fine remodeling around my 125 year old home. Proud to show off my work.
But I thought that floor tiling was a snap well it almost is!
First mistake was assuming the floor was really, really level after laying down cement board. After reading all the helpful hints and watching all most every you tube about tiling I thought man I can do this. I laid my straight edge 6 footer and could see some small space under the edge " but " not much.maybe 1/8 or a hair more.
I was good to go? First mistake I was laying 6" x 24" porcelain tile when working with this type of tile, man you better be flat, real flat but this was not the real mistake I made. I was able to lay my tiles pretty flat it took a lot of re fitting and beefing up areas. Here is the real kicker no where on all the You tubes was it mentioned to be very carful of the razor sharp edges of the tiles.
Here is my error or stupidity as, I call it. I would plop the tiles in their right place and then a wiggle here and another there. using my fingers as tools to move the tiles into the position and then insert the spacer to keep the grout lines straight and true to my chalk line. I only had 45 sq. ft to do but when I had cut, fitted and adjusted the tiles into a nice pattern all was well " EXCEPT "my finger tips were shaved to where I was bleeding on five fingers. two or three on each hand. The razor edges slowly removed my skin a layer at a time.
So I say to you beginners ware a pair of tight fitting gloves.
For the next I, guess 5 or 6 days anything I touch or bump with my finger tips hurts like hell real sensitive pain and bleeds. do I ware a band aid yes sometimes but cuts like these need air to heal and beside washing your hands and off falls the bandages.
Live and learn Robert 75:vs_OMG:
