Hi all, I'm back again looking for your helpful advice.
I'm adding a door to be able to close off a 42" wide hallway from the rest of the house. It's not load-bearing, and from a construction point I'm feeling confident.
I'm planning to remove the existing drywall to tie in to the walls correctly, and I can tie into the ceiling easily enough. My question revolves around the floor. I have a 5/8" subfloor, and a 3/4" underlayment upon which lies carpeting.
As I see it, I have two options. I can cut out the underlayment plywood before framing the door (which probably calls for an oscillating saw I don't have yet), or can I simply cut out the carpeting and padding and set the side jambs on top of the underlayment.
I can see pros/cons to both approaches, but would like to know what you guys would do.
Thanks!
Thanks!
