Hi all,
I'm getting braver, trying to replace a light switch today. It's a standard single pole switch inside a box with 3 other switches. I have a few wiring questions, though, so I make sure I do the right thing.
The timer switch I'm installing is an Intermatic ST01. There are four wires - a red wire, black wire, blue wire, and green wire.
I am following this instruction video to install the switch: http://www.youtube.com/watch?v=RErdw4_Lc0M
Per the instructions, I have capped the red wire because it's only used for a 3 way switch. No problem there. I'm then supposed to connect the black wire to one of the black wires on my existing switch, and the blue wire to the other black wire on my existing switch. Here's my first question. As you can see in the attached pictures, one terminal of my existing switch has two wires connected to the same screw. I'm no electrician, but that doesn't look right. How do I proceed here? Should I connect these two wires and the black wire from the timer switch together in one wire nut? It seems, logically, that that would be the same electrical path.
My second question is about a ground wire. The instructions say to connect the green wire on the timer switch to the ground wire. As you can see in the photos, there is a bare wire that I assume is the ground wire, but it wasn't connected to the original switch. How would I connect this to the ground wire on my timer switch? I am probably incorrect, but it seems like I would cut that ground wire, and pigtail them together with the green ground wire on the timer switch with another wire nut.
Does this make sense? Or am I completely wrong? First switch replacement so I'm a little unsure. :huh:
