Hello,
I have a few questions regarding my plans to put a 60amp subpanel in my detached garage. I realize this is a very popular topic and have done my best to search for answers in this forum before asking.
My plan is to run ~ 30ft of 6-3 romex (protected in walls and joists) from the main panel in my basement to a PVC junction box inside the basement where I will transition to 3 separate 6 gauge THWN2 cables & a 10 gauge THWN2 ground cable (~ 35 ft). The THWN2 cables will be protected in 1 1/4" PVC conduit and run down the wall, into a trench 18" deep to the garage where it comes up and goes inside the garage stud bay to the subpanel.
The plan is to hook up a 60amp breaker in the main panel at the house (its a GE panel) and I purchased a Square D main lugs subpanel for the garage. The subpanel will not have ground and neutrals bonded (no green screw at the top of the panel and a separate ground bus bar installed (that came with the panel). Because it is a detached building I will install two ground rods attached to the subpanel.
The first question I have is how do I transition between the 1 1/4" conduit and the subpanel. Do I just get one of those fittings for the conduit that has male threads and place it through the appropriately sized knockout in the subpanel? I assume I would need some sort of nut to go on the pvc threads and lock onto the subpanel, but I haven't been able to find one. Is this the correct way to join the subpanel or do I have other choices?
I know that the romex has to be stapled with the proper sized staple near the junction box in the house, the main panel and every 3-4 ft along the way, but what do I use to secure the 4 THWN cables? Is there some sort of pvc fitting that has a cable hold downs like you use with romex? Or is it ok just for it to be wirenuted to the 6-3 romex ( which would be stapled near the junction box) and run loose in the conduit?
I purchased a small PVC box 4" x 4" x 4" which I intended to cut a hole into to glue in the PVC fitting to mate with the 1 1/4" conduit that goes outside. This is where I intend to connect the conductors from the 6-3 romex to the THWN conductors. Does that seem reasonable or is there a better alternative?
Another question I have has to do with the ground rods for the subpanel. I purchased 2 8ft long 1/2 copper coated ground rods. Are these sufficient or do I need 5/8" ground rods? The next question is what size ground wire do I need to run from the ground bus bar on the subpanel through the direct burial acorn clamps on the rods? Can I pull the ground cable out of a section of 10-3 romex and use that to connect the rods or do I need thicker cable? Also, do you just literally drill a tiny hole in the side of the garage to put the wire through or do I need to protect it with a little section of conduit?
Thanks,
Christopher
Thanks,
Christopher
