I live in Orlando and am planning on putting in a wooden privace fence. I have several questions, so I've organized them neatly below.
Q1: Permits, surveys and specifications
I have a checklist of items that was sent to me by my homeowners association. I want to make sure all of this gets done right to avoid going back and forth via snail-mail during this approval process. Here are the items they have listed:
1. Written request describing addition, change or installation.
2. Property survey showing where addition/installation is to be located
3. Specifications (copies of plans indicating dimensions and materials)
4. Other (samples, pictures, brochures)
I believe I'm okay with numbers 1 and 4. Are numbers 2 and 3 done by me or someone else. I've heard that I need people to come to my house to do this. Is that correct? If so, who are these people? I know that at some point I need to have the plumbing/electric marked on my property. Is this before or after the approval? We have copies of our property that have dimensions on them.
Q2: Back to back fences
My neighbor has a fence on one side of our property. It's not in terrible condition, but I'd rather put new fencing up around the entire property. Also, it's a different type of fence (same height). We will be using the panel-on-panel fencing for complete privacy. They have the type you can see through. Is it okay for me to put the fence right up against theirs? I know it's probably not an easy task, but I'd rather have it done right all around. I'm pretty certain that his posts have not been placed in concrete. That brings me to my next question.
Q3: To concrete or not to concrete
Being in Florida, I have heard that it is unnecessary to use concrete when placing posts in the ground because of the sandier soil. A lot of the complaints also mention how much of a pain it is to remove the base of the post if it happens to break (due to severe weather). I don't mind either way. I would rather the fence be as strong and sturdy as possible. We are in a compact neighborhood and wouldn't be subjected to the effects of high winds as others might. If it is up to me, I would use concrete. What would you guys suggest?
One other quick question. Do we need specially treated fence and/or posts?
Thank you for any suggestions or comments you might have.
Aaron
Aaron
