my window a/c unit will occasionally trip the breaker..not sure the btu's but its def close to the biggest for a 110 line. nothing else is being used on the line and its a 12g wire on a 20amp breaker. not a 220line...ive noticed that it tends to trip the breaker during what might be a more high usage time for electricity in the neighborhood if that means anything.. i assume its a bad idea to replace the 20amp breaker with a 30 for the time being? also it tends to trip the breaker when on the low setting quicker..i figured that would use less power than the others.. :huh:
