Hello,
Last summer my A/C was working fine with no issues. Come fall we had a blower motor issue with our furnace and had a tech out to replace it. The furnace worked fine. Now this year with the warm weather I turned on the A/C but it did not turn on, more specifically the outside unit does not turn on. The thermostat says cool, it clicks, but the outside unit does not do a thing (not even a hum).
I checked the breaker, outside disconnect, and I even checked for power to the outside unit (all seem ok). Now I figure that there must be a problem from the thermostat communicating with the unit (somehow the signal is not getting to the control board or from the control board to the unit.
I opened the furnace door to take a look at the control panel. I found two things (see attached pic). First there is label A, this is the black/white wires going to the outside A/C unit, as you can see they are not connected to anything. When I check them for power they have a current. When I turn off the A/C breaker the power is gone. My first question is: shouldn't these be connected to something on the control board? Second is label B, you cannot see the end of the black wire here but it is also hanging loosely not attached to anything.
I do not know if the last service tech disconnected these wires but the A/C was working fine before he came to fix the furnace. I did not test the A/C after he left because it was November so there was no need. Maybe he forgot to reattach them or did it for some other reason. I just want to know if these wires should be attached to somewhere on the board because it would explain the issue before I call someone in to fix it.
