Sounds like a load shed.
Does your electric company offer a lower rate if they can shut your A/C off when they need.
Here is the schematic from Edison. Normally if they they ran a 4 wire, Red,White,Green and Blue. Red and white is for the 24 power for the relay and blue and green are for the contacts. BUT without bieng there too see it who knows what they did. YOU NEED TO TRACE OUT THE WIRES. If you don't do it correct (poof the magic smoke comes out):yes:I replaced a circuit board on a Bryant furnace and connected the low voltage wiring up from the t-stat and the condensing unit out side. but now I have a secondary electric meter just for the condensing unit that comes in down at the furnace, 4 wire and I can't quite remember how it went back in.
The unit out side was supplied by the utility company Mod: # 225121 and the catalog # is DCU 1193-1. which I can't find any information on.
I opened the out side box from Edison and found that the red and white wires coming inside the house from Edison are hooked to a transformer and the blue and green wires come from a circuit board with two little relays or at least I think they are relays.
Any help at all would be appriciated
Thank you in advance
Drew Foley
